Bendix
Topic author - Posts: 102
- Last Name: iversen
- * REQUIRED* Type and Year of Model Ts owned: '16 C cab PU, '22 speedster, '23 touring, '25 PU.
- MTFCA Number: 16548
Bendix
No apparent wear of threads or teeth. Best Offer.
Re: Bendix
John, that Bendix may not be for a T. To my eyes, the colar on the end of the spiral is not as wide as that on a T Bendix.
Hope this may avoid some angst.
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
Re: Bendix
This might be a Model A bendix. At first glance, they both look were very similar until you place them side-by-side.
To me, the collar is not as wide as Allan pointed out and of a larger diameter than the T, which is more in line with an A if I remember correctly.
Mark
Mark
Re: Bendix
Allen and Mark, Thanks!! Upon reading your comments I rushed to compare this bendix with two others and not only is the band 3/8" shorter but the spiral threads are in the opposite direction. John Iversen
