NH Full Flow Float Valves - Available this week
Post by Scott_Conger » Fri Nov 15, 2019 5:28 pm
Folks on my waiting list have just been contacted, and I have several left over from the run, so if you're interested, now is the time to get them...
I am still including a free lead washer with each valve, in case you have a particularly stubborn carb that will not seal with the fiber washer. The next run of valves, whenever that is, will NOT include the washer and will have to be purchased separately.
Price is $25 per valve set + $8 postage (tracking and insurance)
If you want just washers alone, still $10 for first 3 and then $2 each after that...and I pay postage.
Please email me with requests rather than responding here...easier for me to keep track of who wants/what...thank you, and thanks for looking
scott
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: NH Full Flow Float Valves - Available this week
Post by Henry K. Lee » Fri Nov 15, 2019 5:42 pm
Very Nice Scott!!!!
Bill Crosby
First Name: Bill
Last Name: Crosby
Post by Bill Crosby » Fri Nov 15, 2019 5:48 pm
Scott,
How much more flow with your float valves?
Bill
Post by Scott_Conger » Fri Nov 15, 2019 6:57 pm
Hi Bill
They flow as much as the original Holley valves flow. Because of the design of the standard replacement valve sold by the suppliers, the flow is through about a .090 orifice and mine flow through .125" orifice which is the original design. There are other improvements, as well, to improve Cv. When you calculate the orifice area of both, you'll find the smaller standard replacement places a considerable restriction into the system compared to the larger, correct one. An additional benefit is the fact that this valve not only has the correct through-put, but unlike any other valve with correct dimensions, this has a Viton tip which will seal more reliably than a hard tip and will not degrade in the presense of alcohol in fuels. See: https://www.calpaclab.com/viton-chemica ... ity-chart/ This does not mean you do not require an independent shut-off valve for safety's sake. ANY gravity flow system can fail and flooding the floor with fuel, whether it be a barn or a basement garage is dangerous!
This was designed to help my dad and his heavy depot hack in E. TN. On steep hills he ran hot, surged significantly, lost power and would sometimes have to let the car sit on side of long hills to "catch up" on the fuel. This sitting led to more overheating, of course. Shifting to low made the problem worse, and quicker. He states that with this float valve, he can make most local hills in high now, and if shifting to low, he marches up the hill just fine. Now, someone's dad may not be entirely impartial, but I have a couple hundred valves in circulation now and have gotten similar statements of improvement from any number of folks.
You see the problem with a restriction is that the float bowl gets low, the jet cannot draw fuel properly, car runs lean, looses power and gets hot and and is now a self-regulating governor on the car. Once it sits a minute, the bowl refills, and once you attack the hill, the same vicious cycle starts over.
Folks who increase the fuel line size, and/or add fuel pumps are all trying to overcome the same problem: Lack of fuel flow, the root cause of which is a too-small of an orifice in replacement float valves. This valve solves the actual cause of fuel flow problems without introducing other variables.
Now...full disclaimer: If you live in flat country and do not exceed 35MPH, you likely DO NOT NEED this valve and the cheaper standard replacement is probably just fine.
Thanks for asking!
Bill Crosby
First Name: Bill
Last Name: Crosby
Post by Bill Crosby » Fri Nov 15, 2019 8:30 pm
Scott,
Thank you for the description.
Bill
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Fri Nov 15, 2019 8:36 pm
Will this work on the Ford NH too? I built one but have not installed it yet. My car is many months away from being roadworthy. No testing has been done with my NH.
Post by Scott_Conger » Fri Nov 15, 2019 9:50 pm
Bill
you're welcome
Mark
Yes, it fits the Ford version, too.
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Fri Nov 15, 2019 10:01 pm
Sent an email
Post by Scott_Conger » Sat Nov 16, 2019 3:43 pm
Bob
I am receiving emails on this, but nothing from you. Sorry about that. Please try again. Thank you
It's Bill
First Name: Bill
Last Name: Hoffer
MTFCA Number: 32571
MTFCI Number: 24364
Post by It's Bill » Sat Nov 16, 2019 5:19 pm
Scott, do these fit a NH straight through carb?
Cheers, Bill
Nv Bob
First Name: Bob
Post by Nv Bob » Sat Nov 16, 2019 6:27 pm
Post by Scott_Conger » Sat Nov 16, 2019 6:34 pm
Bill H
yes, they do.
Roger Byrne
First Name: Roger
Last Name: Byrne
MTFCA Number: 8127
Post by Roger Byrne » Sat Nov 16, 2019 9:09 pm
Sent you an E-mail message.
Preserving Mechanical History for Future Generations since 1965
TLeroux
Last Name: Leroux
MTFCA Number: 20412
Board Member Since: 2010
Post by TLeroux » Sun Nov 17, 2019 9:37 pm
I will take two with washers
tom leroux
Post by Scott_Conger » Sun Nov 17, 2019 11:58 pm
Tom
please send an email for info
thank you
Autie
First Name: Keith
Last Name: Keller
Post by Autie » Mon Nov 18, 2019 7:14 am
I would like one also. Sending you an email. Thank you.
Jrhoads
First Name: Jeff
Last Name: Rhoads
MTFCA Number: 7497
Post by Jrhoads » Mon Nov 18, 2019 8:17 am
Email sent.
