Early spindles
Model T Matt
First Name: Matt
Last Name: Madison
Early spindles
Post by Model T Matt » Tue Dec 03, 2019 11:45 pm
for sale one good one piece spindle and a set of heavy cast spindle arm spindles and one pitted spindle asking $80.00 for the group shipped to you call Matt 503-824-2681
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Re: Early spindles
Post by Herb Iffrig » Wed Dec 04, 2019 7:22 am
I will take them. Email sent.
Model T Matt
First Name: Matt
Last Name: Madison
Re: Early spindles
Post by Model T Matt » Wed Dec 04, 2019 8:40 am
Held for Herb
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Re: Early spindles
Post by Herb Iffrig » Wed Dec 04, 2019 7:42 pm
I have tried to call and have not gotten an answer.
Please send me a message.
Re: Early spindles
Post by Mark Gregush » Sat Dec 07, 2019 12:42 pm
I have one like the bottom two. It has a Ford arm installed for the speedometer setup. The spindle isn't Ford, note that area where the outer bearing rides is not threaded and takes a lock washer with wider tab. Mine does not have the grease fitting. It was suggested that they might be Chevrolet.
1921 Huckster
Model T Tom
First Name: Thomas
Last Name: Butterworth
Re: Early spindles
Post by Model T Tom » Sat Dec 07, 2019 12:52 pm
I will take them if deal doesn't go thru
HornsRus
First Name: Charley
Last Name: Shaver
Re: Early spindles
Post by HornsRus » Sat Dec 07, 2019 2:55 pm
so would i ha,ha. charley
Re: Early spindles
Post by Mark Gregush » Sat Dec 07, 2019 3:32 pm
Notice the flats on them and offset arms;
Early 1922 Parts Lists show spindles with integral arms (one piece). These were described in a letter to the branches dated February 2, 1922:
T280C Spindle assembly, R
T281C Spindle assembly, L
“Starting Feb 6th we will begin making shipments of the above assemblies. The T-280C will eliminate the use of T280B spindle body, T7715B spindle arm, T77 nut, and T82 cotter. The T281C will eliminate the use of T281B spindle body, T7716B spindle arm, T77 nut, and T82 cotter. For some time you will receive both types… We will advise when full production will be new style.”
Then on another letter, dated May 17, 1922, the following”
“We have temporarily discontinued the manufacture of T278D and T279D, spindle assembly right and left. Therefore do not order any more until you are notified to do so. The above assemblies may be replaced with the T280 and T281 spindle bodies and the T7715B and T7716B arms.”
(T280 and T281 are spindles without the bearing cones, T278 and T279 are the same parts with the bearing cones. The one-piece type were never used again in a Model T.)
1921 Huckster
Re: Early spindles
Post by Allan » Sun Dec 08, 2019 3:06 am
Mark's observations are in sync with mine. If I can post such observations before potential purchasers enter the fray, I do so to help. Once a buyer has entered the fray, such observations may queer a sale, and I am hesitant to chime in. How do others feel about these matters? I work from a base that presumes our vendors would not knowingly offer parts which are not accurately represented, so offering advice should help educate vendors and purchasers, thus avoiding any problems with a sale.
MTFCA Number: 14972
MTFCI Number: 15411
Re: Early spindles
Post by RajoRacer » Sun Dec 08, 2019 11:08 am
I agree with you Allan - no way a set of '09 - '10 one piece spindles would sell for $80.00 !
