early steering bracket
Scott Rosenthal
Last Name: Rosenthal
Post by Scott Rosenthal » Sun Dec 08, 2019 10:42 am
WTB #T-932 early steering to frame bracket. This style has no threaded hole for a grease cup, and has the T-932 casting embossment.
Regards, Scott (513)378-4235
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Re: early steering bracket
Post by Michael Paul » Sun Dec 08, 2019 2:26 pm
Hi Scott, I don't have an extra one right now, but I believe there are two slightly different brackets that have t-932 cast on them, one is for the 1909 column , the other is for the early 11 column that is slightly longer, different angle I'll see if I can post a photo of each side by side. What year are you looking for? I have several 932Bs but they're for late 11 to maybe 1915
Mike
Michael Paul
First Name: Michael
Last Name: Paul
MTFCA Number: 31791
Post by Michael Paul » Sun Dec 08, 2019 2:51 pm
Just checked the brackets on my columns, and the 11 has the grease cup hole and the 09 doesn't. Same identical casting number, but slightly different angle. I didn't remember seeing the grease cup hole on the 11. They are the same length at 4 1/4" long. So I answered my own question, you need a 09/10 bracket.
Mike
Scott Rosenthal
Post by Scott Rosenthal » Tue Dec 10, 2019 7:04 pm
Correct Mike. These may have been supplied up into 1911....have heard this but am not the expert. Definitely only one bracket out there that does not have the grease hole.
thx,
Scott
Last Name: House
MTFCA Number: 115
Post by George House » Tue Dec 10, 2019 7:27 pm
Yeah, I have a T 932 B with grease hole too. I looked. You’ll have to go in the Way Back machine to find one of those Scott...
“Fear is a Reaction...
Courage is a Decision”...Sir Winston Churchill
Scott Rosenthal
Post by Scott Rosenthal » Wed Dec 11, 2019 12:44 am
Yep, this is another one of those "rare enough" parts where casting is probably warranted, but then enough folks need to need them to make the cost reasonable. Every once in a while one shows up here. I'm in no great hurry, so we'll see if one turns up. Thanks all.
Scott
Scott Rosenthal
Post by Scott Rosenthal » Tue Dec 17, 2019 10:10 am
TTT
Scott Rosenthal
Post by Scott Rosenthal » Wed Dec 18, 2019 8:47 am
Thanks TBird....I sent Email....will see if a response happens.
Regards,
Scott
