early steering bracket
Posted: Sun Dec 08, 2019 10:42 am
by Scott Rosenthal
WTB #T-932 early steering to frame bracket. This style has no threaded hole for a grease cup, and has the T-932 casting embossment.
Regards, Scott (513)378-4235
Re: early steering bracket
Posted: Sun Dec 08, 2019 2:26 pm
by Michael Paul
Hi Scott, I don't have an extra one right now, but I believe there are two slightly different brackets that have t-932 cast on them, one is for the 1909 column , the other is for the early 11 column that is slightly longer, different angle I'll see if I can post a photo of each side by side. What year are you looking for? I have several 932Bs but they're for late 11 to maybe 1915
Mike
Posted: Sun Dec 08, 2019 2:51 pm
by Michael Paul
Just checked the brackets on my columns, and the 11 has the grease cup hole and the 09 doesn't. Same identical casting number, but slightly different angle. I didn't remember seeing the grease cup hole on the 11. They are the same length at 4 1/4" long. So I answered my own question, you need a 09/10 bracket.
Mike
Posted: Tue Dec 10, 2019 7:04 pm
by Scott Rosenthal
Correct Mike. These may have been supplied up into 1911....have heard this but am not the expert. Definitely only one bracket out there that does not have the grease hole.
thx,
Scott
Posted: Tue Dec 10, 2019 7:27 pm
by George House
Yeah, I have a T 932 B with grease hole too. I looked. You’ll have to go in the Way Back machine to find one of those Scott...
Posted: Wed Dec 11, 2019 12:44 am
by Scott Rosenthal
Yep, this is another one of those "rare enough" parts where casting is probably warranted, but then enough folks need to need them to make the cost reasonable. Every once in a while one shows up here. I'm in no great hurry, so we'll see if one turns up. Thanks all.
Scott
Posted: Tue Dec 17, 2019 10:10 am
by Scott Rosenthal
TTT
Posted: Wed Dec 18, 2019 8:47 am
by Scott Rosenthal
Thanks TBird....I sent Email....will see if a response happens.
Regards,
Scott
