FS. Front Spring Clip/Motor Mount Clamp
d stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by d stroud » Mon Dec 09, 2019 5:59 am
FS. Front motor mount clamp for front spring clip. It is Ford script, but has some wear on one side which can be repaired easily by welding it up or brazing and grinding. Other than that, it is very nice with no pitting or wear on the inside. I don't think these are being reproduced. $10.00 plus shipping in the lower 48. I can text pictures, that's the only way I can. Thanks, Dave
1925 mostly original coupe.
d stroud
First Name: David
Last Name: Stroud
Re: FS. Front Spring Clip/Motor Mount Clamp
Post by d stroud » Wed Dec 11, 2019 2:35 am
Bump. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Fri Dec 13, 2019 4:50 am
This is a very nice clamp except for the bit of wear on it which can be easily repaired. Dave
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Fri Dec 13, 2019 8:53 pm
Spoken for. Thanks, Dave
