Wanted: AC brake parts
Topic author - Posts: 364
- First Name: Stephen
- Last Name: Heatherly
I recently bought a set of small drum ac brakes for my 23 runabout. As is usually the case, the whole linkage set up is missing. Does anyone have an original linkage set for ac brakes? These are operated by a wire rope and pulley system hooked up to the brake pedal. Please let me know if you have a complete set or part of one that you're willing to sell.
Thank you,
Stephen
Thank you,
Stephen
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
Re: Wanted: AC brake parts
Here are some period advertising pictures showing the original setup. Larry Smith is familiar with all the parts and has assembled at least one complete setup for one of his cars.
- First Name: Julius
- Last Name: Korus
- MTFCA Number: 24140
Sent an email
Thank you, Mark. Your help is much appreciated.
Stephen
Stephen
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Hope to do my AC brakes the same way this winter. Would like to see some detailed pictures to help me fabricate mine.
- MTFCA Number: 121
- MTFCI Number: 16310
What baffles me is why both Rocky Mountain and AC repro's have chosen to use rods instead of the original cable set up's which is so much easier to do. It doesn't make sense to me. But what do I know? I have original Rocky Mountain brakes on three of my cars.
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
I could share my own experience. I started to used my AC brakes with cables as original and I found it is not good enough for a brake stability perspective but again it is my perception. So I changed for the rods instead cables and it work much better on my Touring. But again it is probably something personal. If someone is please with cables, it is good either.
Richard Baughman made the AC Branke linkage and it is work fantastic! he's email: richandbertie@gmail.com
Larry Sidmore still making AC Brakes. See bellow pictures and hope that help you.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- Last Name: Cox
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout, 1925 Pickup
Larry,
AC brakes don't come with the linkage.
He leaves it up to the buyer to decide which method to use.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
John Stoltz@ Model T Ranch Makes a equalizer & pedal for setting up large drum brakes to work with the pedel. It looks just like the one for Rockies. I think it will work with just about any outside brake set up. My first set of outside brakes I built a cable system using Chevy truck park brake cables & equalizer, it worked good. I also converted to rods but didn't notice any improvemet how ever I do have a constant rattle to let me know they are still hooked up.
- First Name: Jim
- Last Name: Van Maanen
- * REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
- MTFCA Number: 373
- MTFCI Number: 184
I use a Model T ranch equalizer set up with rods for the original AC's on my 22 coupe. The rods have a set of anti rattle support brackets on them. I needed the rods to eliminate any side to side movement in the brakes as they were a tight fit with hassle rear shocks. Seem to work well, I did add some return springs on the brake peddle.
Thank you all for your help. I believe I have located the parts I need.
Stephen
Stephen
- First Name: DAN
- Last Name: MCEACHERN
Here is a reproduction of the original equalizer setup. I have a few of these. $150.00 each plus shipping. dmcgears@yahoo.com
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
Nice job, Dan! I didn't know you made these.
- First Name: Michael
- Last Name: Peternell
- * REQUIRED* Type and Year of Model Ts owned: TT gas truck, T tractor conversions, '15 touring, '17 speedster, '26 16 valve speedster
Email sent to Dan.
Email sent to Dan.
