Wanted
Topic author - Posts: 2
- First Name: Chris
- Last Name: Chigaridas
- * REQUIRED* Type and Year of Model Ts owned: 1915 Centerdoor Sedan
- MTFCA Number: 0
Wanted
I need a good 1915 left rear axle housing. 805-557-1768
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Wanted
Driver's or Passenger side ? And what state do you reside ?
- First Name: Philip
- Last Name: Lawrence
- MTFCA Number: 5591
- MTFCI Number: 25062
- Board Member Since: 2014
Re: Wanted
Left would be drivers side (No oil filler hole). 1915 would also have no reinforcements ribs on outside flanges ( opposite of wheel, facing center of rear end ).
- First Name: Dennis
- Last Name: Michaud
- * REQUIRED* Type and Year of Model Ts owned: 1909 roadster, 1911 mother-in-law, 1912 torpedo, 1912 touring
- Board Member Since: 2010
Re: Wanted
I have a pair Sandblasted ,clean, and painted, $250 plus shipping
Re: Wanted
Left is the correct description. Passenger or drivers side is confusing when one considers there are LHD and RHD cars. The left side is correct regardless, unless you are one of the
" view from the front" crew who believe a LHD car then becomes RHD.
- First Name: Joe
- Last Name: Kowalczyk
- MTFCA Number: 49558
Re: Wanted
in the US the side is determined from sitting behind the steering wheel, facing forward, drivers side is the left side...
Regards,
Re: Wanted
Joe, that's the point. The left side is the left side when facing forward, regardless of where the driver sits, regardless of the country of origin.
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
Re: Wanted
Allan is correct. Left or right side is determined from where you are setting in the driver's (operator's) seat, no matter which side of the road you are driving on and no matter what you are driving or operating. Dave
1925 mostly original coupe.
