$20 plus USPS small flat rate box postage. Email if interested. I might not see a post here or receive a pm.
Used magneto headlamp dimmer, $20
Topic author - Posts: 1414
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
- Last Name: Kulisiewicz
- * REQUIRED* Type and Year of Model Ts owned: 1919 Express , 1924 Chemicle Fire truck
Re: Used magneto headlamp dimmer, $20
Just curious if anyone knows how or where this mounts? I just purchased one from a member not to long ago... it’s mounted on the same round flange as your is except it has the other half ...in other words it’s two identical halves put together.. just was wondering if anyone had actually seen one mounted?
- First Name: Adam
- MTFCI Number: 1
Yes, they mount in place of the ammeter and a metal plate covers the hole and hides the transformer.
I see ... ok thank you Adam!
