Ball cap , re-babbitted and bored to Std. or your specified diameter
Topic author - Posts: 835
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Model T Ford ball cap , re-babbitted and finish machined to standard diameter or your specified diameter … ball caps are sold outright with NO EXCHANGE necessary … price is $45 plus $13.60 priority mail postage in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn, Co. 80648 phone 970-581-2808
- First Name: Gene
- Last Name: French
Re: Ball cap , re-babbitted and bored to Std. or your specified diameter
can bore the ball cap on any size as needed … I recommend .002" clearance over clutch plate shaft diameter ...gene French 970-581-2808
- First Name: Gene
- Last Name: French
Gentlemen:
can deliver to Chickaha Swapmeet March 15-16 … will be at space SL4 in south building ...always an optimist Gene French 970-581-2808
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
top... purchased a quantity of ball caps for re-Babbitt ...
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
to the top again , thanks MTFCA
- First Name: Marshall
- Last Name: Daut
Hey, Gene! We're sending you an order. Is that street address complete? 'Seems like something is missing: 49519 cr.23.
Marshall
Marshall
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- MTFCA Number: 121
- MTFCI Number: 16310
Gene: Why not think about rebabbiting camshaft bearings?
- First Name: Gene
- Last Name: French
Larry:
i have re-babbitted cam bearings for my own use ... this requires that you start with good shells , the bearing halves are often worn out of round on the outside diameter ... this condition and any wear in the bearing bore of the block makes for a loose bearing ... also , the difficulty in getting an ample supply of good cores make this an unattractive venture ... always an optimist ...Gene French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
to the top again ...thank you MTFCA
- First Name: Gene
- Last Name: French
the current pricing on the re-babbitted ball caps is $50.00 plus $16.20 postage in lower 48 states ... actual postage outside this area ... always an optimist ...Gene French
- First Name: Gene
- Last Name: French
to the top again ...thanks MTFCA
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
