WTB accessory spring bolts
csnailnrun
First Name: Ryan
Last Name: Snellen
* REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
Post by csnailnrun » Thu Dec 26, 2019 3:55 pm
I’m looking for two bolts for the front of this spring accessory. This is bolt replaces the standard perch bolt which must be 5/8 longer. Same diameter of course. Any ideas of where to get a proper fitting bolt? No luck at Fastnal. Maybe someone has the correct bolts for this? Thanks!
Last Name: Gregush
MTFCA Number: 52564
Re: WTB accessory spring bolts
Post by Mark Gregush » Fri Dec 27, 2019 12:05 pm
Think that there would 3 way to go about this, find the original bolts, use a wrong bolt or have them made. You would need a bolt that is non threaded along its length, has the same end as the perches to mount the wish bone, has the extra length added for thickness of the leafs and fits tight in the axle hole. Maybe I am missing something, but I would leave them on the shelf and use the stock perches. Looks like you would now be relying on only the wishbone to set the angle of the axle which is what the perches do, unless they have the angle built in or there is a missing part where they mount to the axle. You don't want to mess around with changing the geometry of the front end, it could lead to bad results.
1920 Dodge touring
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Dec 27, 2019 12:25 pm
Mark, Ryan and I talked about exactly what you just covered. Making him the era correct items! LOL
HANK
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Dec 27, 2019 12:33 pm
If you have a lathe, a junk T axle or driveshaft, and a little time... that’s how these bolts came about
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
* REQUIRED* Type and Year of Model Ts owned: 26 coupe and 23 Runabout
Post by Stephen_heatherly » Fri Dec 27, 2019 1:10 pm
Personally I wouldn't use those on my car. The quality of a lot of T accessories is very questionable and failure in a critical suspension part can go very badly.
Stephen
Post by Scott_Conger » Fri Dec 27, 2019 2:35 pm
yeahhhhhhh.....no
not for me
garage art in the display case
NH Full Flow Float Valves
