Rocky Mountain Brake pedal
Topic author - Posts: 44
- First Name: Thomas
- Last Name: Mock
- * REQUIRED* Type and Year of Model Ts owned: 1923 Roadster
- MTFCA Number: 50414
WTB Rocky Mountain Brake pedal. I only need the bake pedal - have the rest. Thanks!
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
Re: Rocky Mountain Brake pedal
If you don't find one, Chaffins, Langs, Snyders etc carry them. If you find one, make sure it has the cams. There are some out there that don't. You would end up with just the outside brakes if it does not have them.
1920 Dodge touring
1920 Dodge touring
- Last Name: Mock
Thanks for the info. It is much appreciated. Tom
- First Name: Joe
- Last Name: Kowalczyk
- MTFCA Number: 49558
Attached picture shows the pedal Mark is mentioning NO CAMS, I purchased this car with this pedal and no brake band in the transmission, I have since installed a brank band and pedal with the cam.
Regards,
