New NH and Vaporizor Float Valve install tool available
Topic author - Posts: 2755
This will install or remove my Full Flow Float Valve or the common commercial valve offered by vendors for your NH or Vaporizor carburetor. It will NOT work correctly on original valves as the pilot is a different size, nor will it work on Grose Valves. They come out with a screwdriver anyway, with a little damage, or in the case with the Grose valve, a nut-driver.
This tool will not slip off the valve, risking damage to the valve upon installation like a simple screwdriver will.
I have tried to keep the price down, so while the drive-dog is hardened, the rest of the tool is NOT hardened. However, I believe it will hold up just fine unless intentionally abused, and even then I suspect it will take it's share and shrug it off.
I am only making 10 to start and will only start if there is interest, and the first one may already be spoken for. So, contact me via email to get on a list and if there are 10 enough folks in a reasonable time, I will make them and deliver them to your door for $35.
So note: This is Pre-Order only at this time, to gauge interest. I will stay in contact with you and give thumbs-up or down, based on response.
Please email your response to me, so that I can keep track. Thank you and Thanks for looking.
Last edited by Scott_Conger on Fri Jan 10, 2020 10:53 pm, edited 3 times in total.
- First Name: Bill
- Last Name: Anziani
Re: New NH and Vaporizon Float Valve install tool available
Scott, I will take one of your tools
- Last Name: Hatch
- MTFCA Number: 49974
Put me on the list. Dan
- First Name: Brad
- Last Name: Kirtner
- MTFCA Number: 50618
I’ll take one too.
Brad
Brad
- First Name: Paul
- Last Name: Carreras
- MTFCA Number: 14727
- MTFCI Number: 13768
I would like to get one of your float valve tools.
Paul Carreras
Paul Carreras
- First Name: Mike
- Last Name: Lebsack
- Board Member Since: 2008
Hey Scott,
Got your valves, better have a tool too. Mike Lebsack
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
Good for you. Jack Daron made a similar tool for years but he is no longer with us.
Someone made me a tool for removing the lower jet in Holley G's and sent it to me years ago.
It is a great tool. One end removed the float valve and the other the bottom jet.
So here is free method advice.
Chuck the tool in your drill press chuck. Hold the carb in a vise. Apply down pressure while turning the tool handle. The pressure will keep the tool from slipping.
- First Name: Darryl
- Last Name: Bobzin
- MTFCA Number: 27211
Re: New NH and Vaporizor Float Valve install tool available
Put me down for one of these tools please. Darryl
- First Name: Bill
- Last Name: Harper
- MTFCA Number: 5414
Hello Scott,
I will buy one of your Float Valve tools AND a float valve, too.
Sending an email as well. Thank you, Bill.
- First Name: GG
- Last Name: Gregory
- First Name: William
- Last Name: Goble
- MTFCA Number: 31190
- MTFCI Number: 24534
Hi Scott I will buy one as will . what is your email ?
- First Name: Terry & Sharon
- Last Name: Miller
- MTFCA Number: 32583
Hi Scott,
As Mike and others above have said: I have your High Flow Valves. I haven't used them yet but still plan on doing so. I would like to have one of your tools as well. I know I am the tenth in line and you already said #1 may be spoken for, thus, I may have to wait until the second batch. OR, you might consider making eleven and a little more cash.
Thank You, My Friend,
Terry Miller
Terry Miller
Thank you all for your responses. This first order will go ahead.
I will commit to making tools to fill requests up to Terry Miller. Further requests will be put on a waiting list, which hopefully will be filled without too much delay.
thank you all for looking
- First Name: Clyde
- Last Name: Gibson
- MTFCA Number: 32266
I have the float valve you made so I will take the tool also. Clyde Gibson
- First Name: Clyde
- Last Name: Gibson
- First Name: Tom
- Last Name: Strickling
I would also like one of these tools. Thanks for making them.
Tom Strickling
Tom Strickling
- First Name: John P.
- Last Name: Steele
- MTFCA Number: 374
- MTFCI Number: 137
Scott I would like to purchase one also.
Thank you,
John
Thank you,
John
- Last Name: Magill
- MTFCA Number: 4444
Scott I would take one too if available thanks Tim
- Last Name: Willams
- MTFCI Number: 20566
Scott: Hi From Iowa! Since I already have 2 of your nice valves I guess you can put me down for one of the tools! No Hurry - John
- First Name: Danny
- Last Name: Deaton
Scott
Put me on the list
Put me on the list
- First Name: Ervin
- Last Name: Mims
- MTFCA Number: 29375
Put me on the list to please
- First Name: Clyde
- Last Name: Gibson
I will take one of your tools. I already have your float valves
