Cast iron Warford - Complete
Topic author - Posts: 47
- First Name: Randy
- Last Name: Clemens
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup, 1926 Roadster, 1927 Fordor
For sale: Cast Iron Warford transmission - $100. Randy newtexaz@gmail
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Re: Cast iron Warford - Complete
Hi Randy,
Is that a 2 or 3 speed? Thanks
- Last Name: Maslack
Not mine, but definitely a two speed...They are easier to shift as they have dog clutches of a sort..
- First Name: craig
- Last Name: leach
Ive heard they shift better, I'm mainly looking for a case for one of mine but I need a three. thanks
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Craig, Not sure if this is a 3 speed but is on ebay # is 920-1
https://www.ebay.com/itm/Warford-Model- ... Swlx9cJoZD
- MTFCA Number: 14972
- MTFCI Number: 15411
That's a late model 3 speed w/PTO capabilities.
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
- MTFCA Number: 50618
With it being a 2 speed, is it just under/direct or under/over?John M Maslack wrote: ↑Mon Jan 20, 2020 12:12 pmNot mine, but definitely a two speed...They are easier to shift as they have dog clutches of a sort..
The ones I have seen are under and direct. Woodward made a two speed that could be had under and direct, or direct and over...
- First Name: Ryan
- Last Name: Snellen
- * REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
Someone correct me if I'm wrong, but the straight shift handle is Under/Direct whereas the dog leg shifter will have all three gear options.
- Last Name: Knapp
- * REQUIRED* Type and Year of Model Ts owned: 1919 Speedster (project)
Actually, I have looked at many Warford 3-speeds with straight shift levers. I do not think they were manufactured with a dogleg, I think someone bent the levers that way to make them fit their installation, at least until the Model A Warfords.
The shift tower looks much like the 2nd version of the aluminum 3-speed Warfords. I would like to see a photo of the shift tower from the top looking down. A 3-speed has 2 shift rods which slide forward/backward. A 2-speed has only one shift rod to slide like that. All 3-speed Warfords up through at least serial number 75938 were aluminum. All after serial number 81965 were cast iron. The transition from aluminum to iron was somewhere between those numbers.
I am not sure on the "420-1" casting number either. Aluminum Warfords had no such casting number up through at least serial number 7646, but do show a PSB logo (Partridge, Singer & Baldwin). The earliest numbered aluminum Warford after the PSB's that I have seen is number 52798, and that case shows a "720-1" casting number. So is the 420-1 actually a 2-speed? I would love to have a serial number off of it, and a top photo to add to the data I am collecting. / Tim
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
Tim while you are here, did the 2 speed Warford come in ether under/direct and over/direct? I think they did. My lever was straight on the cast iron 3 speed, but I too bent it for more room.
1920 Dodge touring
1920 Dodge touring
