WHEEL BERG PACKER,
Posted: Fri Jan 24, 2020 1:14 pm
by Richard G
I KNEW I HAD THIS ITEM , ITS USE FULL WHEN PACKING GREASE IN A WHEEL BERG, YOU STILL GET THE HAND GREASY BUT THE BERG'S GET FILLED
- https://www.mtfca.com/phpBB3/download/file.php?mode=view&id=41940
- https://www.mtfca.com/phpBB3/download/file.php?mode=view&id=41939
- https://www.mtfca.com/phpBB3/download/file.php?mode=view&id=41938
IT WILL PACK A GOOD SIZE BERG. BY PLACING THE WIDE SIDE OF BERG ON BOTTOM OF PACKER AND THREADING TOP HALF DOWN TIGHT MOUNT THE GREASE GUN TO THE FITTING AND PUMP , TO TELL WHEN BERG IS FULL OPEN COVER TO CHECK .IF NOT RE TIGHTEN COVER AND GIVE IT ANOTHER SHOT TILL IT IS, $20 PLUS POST ITS MADE SO YOU CAN REMOVE THE FITTING AND THRED THE GREASE GUN HOSE INTO TOP FITTING FOR A PERMANENT FIXTURE.
Re: WHEEL BERG PACKER,
Posted: Fri Jan 24, 2020 4:47 pm
by kirbypray
I’ll take it! I’ll pm you.
Posted: Sat Jan 25, 2020 9:23 pm
by Richard G
PACKER IS SOLD
Posted: Sat Jan 25, 2020 11:11 pm
by Jeff Hood
Both cones should be oriented in the same direction. The bearing gets greased and you can see that the grease has gone all the way through. You don't have to take it apart to see the bearing. Also uses less grease.
Posted: Wed Jan 29, 2020 8:26 pm
by Richard G
THANK YOU JEFF, I RELAY'D INFO TO KIRBY.
