7 Rivet Engine Pan
ThreePedalTapDancer
First Name: Ed
Last Name: M.
7 Rivet Engine Pan
Post by ThreePedalTapDancer » Fri Jan 24, 2020 7:47 pm
Original 1912 or earlier 7 rivet engine pan, with the reinforcing plate under the seven arm rivets. Has been welded and repaired in the inner corners. Lots of sloppy extra brazing evident around the arms, nose and various places, obviously very old reinforcing by previous owner. It has a brazed patch on the bottom of the hump, also done a very long time ago. It is still a solid pan, no cancer or rust out evident. Just needs to have some of the welds and brazing cleaned up for appearance. Very hard to find pan. Can provide more detailed pictures if needed. Pick up required or arrange your own shipping. 500.00
Michael A
First Name: Michael
Last Name: Abbott
MTFCA Number: 12345
Re: 7 Rivet Engine Pan
Post by Michael A » Sat Jan 25, 2020 2:19 am
Hi Ray
Can you send some close up pictures of the repaired section.
michaelcraigabbott@gmail.com
Tbird
Last Name: Bird
Post by Tbird » Sat Jan 25, 2020 11:10 am
Interesting pan and the transition details. The front casting looks like the later narrow nose pans without the front casting going completely around the hole. Might be a really late 12 early 13 and or last of the 7 rivet arms being used up. Interesting
Tbird
Last Name: Bird
Post by Tbird » Sat Jan 25, 2020 11:12 am
My 7 rivet has the plates behind the ears and the casting that goes completely around the hole.
ThreePedalTapDancer
First Name: Ed
Last Name: M.
Post by ThreePedalTapDancer » Sun Feb 09, 2020 2:40 pm
Bump. Still have it, come and get it.
ThreePedalTapDancer
First Name: Ed
Last Name: M.
Post by ThreePedalTapDancer » Sun Feb 23, 2020 1:46 pm
Accepting offers
Markb
Last Name: Barlow
Post by Markb » Mon Feb 24, 2020 12:09 pm
Can I come pick it up for 350
Markb
Last Name: Barlow
Post by Markb » Wed Feb 26, 2020 4:14 pm
where do you live?
Mark
ThreePedalTapDancer
First Name: Ed
Last Name: M.
Post by ThreePedalTapDancer » Fri Mar 06, 2020 9:38 am
Nobody has even come over for a look see, back up into the rafters it goes....
