7 Rivet Engine Pan
Topic author - Posts: 1419
- First Name: Ed
- Last Name: Martin
7 Rivet Engine Pan
Original 1912 or earlier 7 rivet engine pan, with the reinforcing plate under the seven arm rivets. Has been welded and repaired in the inner corners. Lots of sloppy extra brazing evident around the arms, nose and various places, obviously very old reinforcing by previous owner. It has a brazed patch on the bottom of the hump, also done a very long time ago. It is still a solid pan, no cancer or rust out evident. Just needs to have some of the welds and brazing cleaned up for appearance. Very hard to find pan. Can provide more detailed pictures if needed. Pick up required or arrange your own shipping. 500.00
- First Name: Mike
- Last Name: Bird
Re: 7 Rivet Engine Pan
Interesting pan and the transition details. The front casting looks like the later narrow nose pans without the front casting going completely around the hole. Might be a really late 12 early 13 and or last of the 7 rivet arms being used up. Interesting
- First Name: Mike
- Last Name: Bird
My 7 rivet has the plates behind the ears and the casting that goes completely around the hole.
- First Name: Ed
- Last Name: Martin
Bump. Still have it, come and get it.
- First Name: Ed
- Last Name: Martin
Accepting offers
- Last Name: Barlow
- * REQUIRED* Type and Year of Model Ts owned: 1921 touring, 1911 under construction
Can I come pick it up for 350
- Last Name: Barlow
where do you live?
Mark
Mark
- First Name: Ed
- Last Name: Martin
Nobody has even come over for a look see, back up into the rafters it goes....
