Private messages: Outbox vs Sent messages
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sun Jun 27, 2021 11:09 am
Yesterday, I replied to a private message from another forum member.
After I pressed "submit," the reply has been sitting "Outbox" folder for the last 12 hours instead of the "Sent messages" folder.
How do I know if the message has been actually sent to the intended party?
Thank you for your help.
MTFCA Number: 52564
Re: Private messages: Outbox vs Sent messages
Post by Mark Gregush » Sun Jun 27, 2021 4:26 pm
It has been put in the out box and is waiting for the recipient to open and read it. Once it is opened and read, it will be marked sent. If you had that message open and clicked reply, then that is who it was sent to. Sent messages have been opened and read, are then saved to that file.
1920 Dodge touring
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sun Jun 27, 2021 9:15 pm
Thank you for the reply and the explanation.
The message is now in the "sent" file so the recipient has opened and read it.
MTFCA Number: 52564
Post by Mark Gregush » Mon Jun 28, 2021 8:49 pm
Ok good to go! :)
1920 Dodge touring
