adding fuel pump
braddyer
adding fuel pump
Post by braddyer » Thu Sep 23, 2021 2:07 pm
l am adding a fuel pump need to lower fuel pressure any suggestions
Last Name: Gregush
MTFCA Number: 52564
Re: adding fuel pump
Post by Mark Gregush » Thu Sep 23, 2021 2:20 pm
Simple, add a pressure regulator set to 1-1.5 LBs. Suggest if you have questions, sign-up and ask your question on the general forum. This is not the section to ask car related questions. When you do sign-up and post, tell us why you think you need a fuel pump, because that will come up. Is this Ford Model T related or hot rod?
1920 Dodge touring
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Thu Sep 30, 2021 1:22 am
Another ghost! Tis almost the season! :twisted: Ma-ha-ha
1920 Dodge touring
