Unable to keyword search “2018 & Prior Forum”
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Sat Apr 18, 2020 11:35 pm
Is there any reason why I am unable to keyword search the “2018 & Prior Forum”? When I try to access it, the “2018 & Prior Forum” page appears, but when I try to access the keyword search feature, a notice comes up saying “the server encountered an internal error or misconfiguration and was unable to complete your request” and says to contact the MTFCA server administrator, so here I am. Jim Patrick
Last Name: Gregush
MTFCA Number: 52564
Re: Unable to keyword search “2018 & Prior Forum”
Post by Mark Gregush » Tue Apr 21, 2020 10:54 am
I just use a google search and am able to access/read subjects posted that go back for quite a few years. "mtfca; magneto" yields;
https://www.google.com/search?client=fi ... 3B+magneto
1920 Dodge touring
Duckwing
First Name: Jim
Last Name: Wilson
Post by Duckwing » Tue Apr 28, 2020 9:57 pm
Used Google search but the results are limited and did not included the thread I previously found and am interested in resurrecting. Is there no answer re this issue.
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Wed Apr 29, 2020 10:17 am
Are others having this same problem of not being able to access the “2018 and prior forums” keyword search? Jim Patrick
ChrisB
First Name: Chris
Last Name: Brancaccio
MTFCA Number: 443
MTFCI Number: 23136
Post by ChrisB » Wed Apr 29, 2020 1:49 pm
Per Mark above, Google is the best to use for searching, always has been.
"your search term" site:www.mftca.com
rear axle drawings site:www.mftca.com
2 or 3 words is usually sufficient, leave out all the small words.
The last update to the website software broke some of the old forum software code which I will have a look at as time permits.
Chris
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Duckwing
First Name: Jim
Last Name: Wilson
Post by Duckwing » Wed Apr 29, 2020 4:54 pm
Thanks for the input. What is strange, last week a few times I was able to do a word search the "old way" and it worked fine then didn't. It does not appear that when I use the Google method that I get all the results I did with the old way but may but may be my imagination.
Jim
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Thu Apr 30, 2020 1:00 am
If you know who the author try that in the google search, for example;
mtfca jiminbartow
https://www.google.com/search?client=fi ... iminbartow
1920 Dodge touring
