Oil check petcocks thread size
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
MudsT
First Name: Doug
Last Name: McCallister
* REQUIRED* Type and Year of Model Ts owned: 1926
MTFCA Number: 50114
MTFCI Number: 24799
Post by MudsT » Tue Jun 23, 2020 9:09 pm
Been dealing with drips from my oil check petcocks on my 26 Canadian built coupe. Thought that I'd just change them out with new ones, original style, from Lang's. Removed old petcocks but new ones seem to be larger diameter and will not screw in. Anyone have an idea why this might be such a problem? Difference between USA and Canadian built. Lang's part issue?
Re: Oil check petcocks thread size
Post by Scott_Conger » Tue Jun 23, 2020 11:02 pm
1/8 NPT is a tapered thread. There is some chance that the die was not threaded on far enough, I suppose.
NH Full Flow Float Valves
MudsT
First Name: Doug
MTFCA Number: 50114
MTFCI Number: 24799
Post by MudsT » Wed Jun 24, 2020 6:08 pm
Scott,
I picked up a die for that thread. After some iffy starts I did manage to run the die down further than threads supplied. Reversed the die and chased threads further. Now catching several more threads and new petcocks will work. Thanks again great info. Doug
Post by Scott_Conger » Wed Jun 24, 2020 6:36 pm
I'm glad it worked, but it is a tapered thread and the die is not reversable and still get the designed thread. If it doesn't drip, then no harm no foul and am glad you're moving forward with your project.
