How to get to older forums?
Can’t log in? Having a problem with the Forums? Have a question about how something works? Get support here.
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Tue Jul 14, 2020 12:13 am
I am trying to find the forums for 2010, specifically the ones dealing with a home-built crank type coil tester and adjuster, I think from the November 2010 forums. How to I get to them?
Last Name: Gregush
MTFCA Number: 52564
Re: How to get to older forums?
Post by Mark Gregush » Wed Jul 15, 2020 7:45 pm
google "hand crank coil tester" You can access 2017 and 2018 thru the main menu on the forums list. Other wise you need to do the suggested search and look for dates in what you find.
I found this doing so;
http://www.mtfca.com/discus/messages/80 ... -93057.pdf
1920 Dodge touring
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Wed Jul 15, 2020 11:20 pm
Thanks very much! That is exactly what I was looking for!
BIll
