Photos
- MTFCA Number: 52564
Re: Photos
Under the message box, click on "Attachments", when that opens click on "files". That opens the window to load photos from your files. When you find the ones you want to post hold the "Ctrl" key down and pick the ones you want to load (up to 5 per posting). After you have picked the ones you want to load release the "Ctrl" button. Then click "open" in the file upload window. That window will close and you should see the files being loaded on the page. If the photos are loaded, it will show green or not loaded. If you have more then 5 to load, don't start a new subject, load them as replies to the first posting.
Hope that helps.
Mark
Hope that helps.
Mark
1920 Dodge touring
1920 Dodge touring
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
Re: Photos
I think you can also just click and drag photos into the text box, like this. Hey, it worked!
