Profile Picture Posting problems
Posted: Tue Jan 08, 2019 7:49 pm
by Novice
I have tried till i am blue in the face and cant get file smaller than 100X75 which wont cut it. This is much worse than the old forum for posting pictures and I thought it was bad. Perhaps Chris can post detailed instructions on how to do it in different formats. Been better if profiles could have been transfered to new forum. :oops:
Re: Profile Picture Posting problems
Posted: Tue Jan 08, 2019 9:48 pm
by n7qvu
If you're using Windows, look for PAINT. Load up your pic and in the upper left is a resize button, select 90pix, then save it.
Hope this helps, others have suggestions in another post topic.
Posted: Tue Jan 08, 2019 10:04 pm
by Charlie B in N.J.
Win 10. Paint drove me nuts. Microsofft store offers free resizer apps. I picked & downloaded the first one. (Image Resizer) .Gives one dimention which you have to lower to around 73. Save it. when it appears in your pic file it'll tell you the length & width pixels. Both under 90 & your in. Regular pic posting doesn't require any thing to be done it's only for the avitar photo. I went as wild as you but it's OK now.
Posted: Tue Jan 08, 2019 11:36 pm
by tmodeldriver
Thought I'd jump in here and see what happens. Bob Hester
Posted: Tue Jan 08, 2019 11:39 pm
by tmodeldriver
Well, there you go. No profile picture anymore. Don't know how to get it back. :(
Posted: Wed Jan 09, 2019 12:48 pm
by Novice
Charlie B.Many Thanks! PROBLEM SOLVED. Image resizer did the trick once I found which file the resized photo went to. I didn't want to push My luck and try to crop the picture in order to make the car bigger. REAL PAIN IN THE BUTT! But it's done and I learned a lot. :D
