Forum failure this AM - we caught it.
Posted: Fri Jan 18, 2019 11:11 am
by AdminJeff
We know the site went down this AM. I was actually monitoring it when it went down so I have lots of data for the ultra-techie Linux support geeks to pour over. We're trying to track down the root cause. It's a thorny issue. Rest assured both ChrisB and I are all over this.
Sorry for the delay in getting it back online this AM. Sometimes you need to keep the system in a failed state so you can do forensic analysis and figure out why its happening. I can assure everyone we'll only do that when absolutely necessary and get it back online ASAP. I personally know how addicting these forums are at 3AM!!
I'm going to take one for the team here. if you notice the site go down, send me a TXT "MTFCA SITE DOWN" to Seven 0 Seven - 532-5773
Please only send me a txt only if you get this parrticular error when trying to access the site:
pls don't do it at 3am... if that happens, email jeff at vinopro dot com or ChrisB.
For other support issues, we'll use the (working) forums for that.
Jeff
Re: Forum failure this AM - we caught it.
Posted: Fri Jan 18, 2019 11:22 am
by RustyFords
My phpBB board crashes about twice a year.
It's fairly easy to fix
Posted: Fri Jan 18, 2019 11:26 am
The same day that the private messages was taken off I received the same notice when I tried to sign in.
Posted: Fri Jan 18, 2019 11:29 am
by Novice
THANKS. FYI the forum was also down yesterday 12-17-2019 for a while. I figured You guys were working on it. So I did not report or post outage it came back up after a while.
Posted: Fri Jan 18, 2019 12:01 pm
by DLodge
Thanks, Jeff. I have added your phone to my contact list in the fervent hope that I will never have to use it. :D
Posted: Fri Jan 18, 2019 12:17 pm
by AdminJeff
Yes, its easy to fix - restart the server. The question is WHY? what is causing it? babysitting forums that thousands of folks use for crashes isn't fun... so we're on a search and destroy mission and we won't stop until we nail it.
Jeff
Posted: Fri Jan 18, 2019 12:34 pm
by RustyFords
Jeff
I'm not running my own server. If yall are...then bless you. And may the force be with you.
Posted: Fri Jan 18, 2019 12:41 pm
by Tiger Tim
Did someone install a filter on the forum when it was being set up? The internet is electrical but it seems 99% of electrical problems are actually fuel, after all...
Posted: Fri Jan 18, 2019 3:35 pm
by AdminJeff
The only filter we considered installing was the "Check if user is a little wacko before allowing posts" Filter. We opted to not install that filter since I wouldn't be able to post and help you guys. :shock:
Jeff
Posted: Fri Jan 18, 2019 3:56 pm
by Ruxstel24
Jeff
I resemble that remark !! :lol:
