aluminum intake manifold and carburator
Topic author - Posts: 849
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
for sale: aluminum intake and aftermarket carburator ( model A carb. )... this is an aftermarket ( performance?) manifold of unknown manufacturer ... carb. will benefit from a rebuild ... manifold has a 1/8" pipe thread at elbow ... a simple pipe plug to close or use with vac. wipers or vac.tank for fuel supply ... price is $75 plus $15.05 flat rate postage in lower 48 states ... actual postage outside this area or INTERNATIONAL ... always an optimist Gene French 970-581-2808
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Re: aluminum intake manifold and carburator
The intake is a UJ some like them.
- First Name: Ryan
- Last Name: Snellen
- * REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
I’ll take the intake Gene. Sent you a text. Thanks!
- First Name: Gene
- Last Name: French
the intake/carb. is spoken for ...thank you Ryan S. and MTFCA
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
There should be a rule that you can't post anything really cool for sale before I get up, have breakfast and am checking the classifieds!!!
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Stan, that U & J Manifold was speaking to you huh ? !
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
That is the same setup I have on my speedster works super. takes alittle work to set up the throttle and mixture adjuster but works great!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Stan,
the prescription for beauty rest is not working for me either according to the wife. But she is over due an eye exam anyway!
