No Longer Available
Topic author - Posts: 253
- First Name: Chad
- Last Name: Marcheese
- * REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Doodlebug / 1924 Speedster Gow Job
- MTFCA Number: 26904
No Longer Available
No Longer Available
Last edited by Chad_Marcheese on Thu Aug 13, 2020 8:47 pm, edited 2 times in total.
- First Name: Chad
Re: Spindles with straight steering arms
No Longer Available
Last edited by Chad_Marcheese on Thu Aug 13, 2020 8:47 pm, edited 1 time in total.
- Last Name: Mazza
- * REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
The arms are the early style with the speedometer mount hole.
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
Chad, you do not want to be using the one with the notch. That is from a washer that got loose and cut a groove.
Work honestly
Stay true to your word
Get the job done right
Chad, the spindle with the wear grove is the later type with the flats on the shoulder so the bearing can be driven off, so it is no great loss.
- First Name: Chad
Thanks gentleman. I do realize the grooved spindle is not what I would use personally. As mentioned in my ad, the arms are the real value here.
If someone just wants the arms, I will remove them. Just trying to clear out some parts that are around here.
