Model T Tractor Conversion Hubs
Topic author - Posts: 40
- First Name: Wallace
- Last Name: Bellows
- * REQUIRED* Type and Year of Model Ts owned: To Many!
- MTFCA Number: 15547
These gear hubs came off of a Model T rear end I picked up with some other T parts. I don’t know what tractor conversion unit used these but they look a little like Shaw but I’m really not sure. There are casting marks on each hub G2067. They have a little wear but don’t look like they’ve been used much.
$150 for the pair
$150 for the pair
- First Name: Michael
- Last Name: Peternell
Re: Model T Tractor Conversion Hubs
Your gears are in great shape. One tooth light and a flange heavy for Shaw. Worth twice what you are asking if the right guy wants them.
New Shaw gears. I do not have any for sale. Not trying to highjack an add!-
Thanks for the info. Do you think these are Shaw or to heavy to be Shaw? I’m not familiar enough with Shaw to know if they made gears with a flange. Your right that they don’t even look like they were barely used. 7 tooth would probably increase your pulling power too.
- First Name: William
- Last Name: Weiss
- MTFCA Number: 20215
- MTFCI Number: 16460
I will take them email sent
Thanks Bill
Thanks Bill
Hubs sold!
Thanks Bill
(PM sent)
Thanks Bill
(PM sent)
So Mr Weiss, inquiring minds want to know. What's the manufacturer? My guess monkey Ward's?
- First Name: Glenn
- Last Name: Heim
Bill must have a Pullford built between 1930 and 1941 because that is what the gears are for.
I was wondering what these were. I kinda thought monkey Wards also and I wasn’t really sure if they were Shaw.
Thanks for the id Glenn
- Last Name: Weiss
Here is a follow up on the hubs.
They are smaller that others I have seen.
Too small for a Sears Conversion.
Too small for Pullford Model A or Model T Conversion.
Photo for comparison.keep getting yellow triangle when I try to load photos.
- First Name: Glenn
- Last Name: Heim
Bill What type of tractor conversion were you planning on putting them on?
- Last Name: Weiss
I wanted to use with a Sears Conversion but these are way small and do not mesh with drive gear
They are half the size of Pullford conversion.
- First Name: Glenn
- Last Name: Heim
What year or style of Sears conversion kit do you have? Do you have worn gears or no gears?
- Last Name: Weiss
No pinion gears
Will email you a photo when the sun comes up.
My photos won't load for some reason.
- Last Name: Weiss
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 snowmpbile Staude and Shaw tractor conversions, Model T powered sickel bar mower
Hi Bill,
Have you made any progress with the saw I sold you??
TOM
TOM
- First Name: Greg
- Last Name: Popove
- Last Name: Weiss
- First Name: Glenn
- Last Name: Heim
Bill The pinions behind the late Pullford's are for a Model A Sears conversion. Are you building a Model T or an A Sears conversion? Your conversion is 1937-about 1941(end of production). The width of your rim determines the approximate age of your conversion. The rim width became smaller every couple of years as the 30's progressed.The saw rig you bought is based on a 1917-mid 20's Staude tractor attachment. It is such a great setup! I hope you leave it like it is. Do you still have your snowmobile? A 44 gauge?
- First Name: Glenn
- Last Name: Heim
Bill-Do you need Sears Model T pinions or are you looking for better Model A pinions?
