In the past, JB Weld made one product which most of us have used and are familiar with, which is the two part moldable epoxy putty. Recently, JB Weld has started making a thin, two part transparent epoxy glue that comes in a double tube syringe and also a version for larger jobs that comes in two large squirt bottles.
Since these two JB Weld products are used for different purposes, I think that when we recommend that “JB Weld” be used for a certain purpose, we should specify which type of JB Weld we are referring to. The putty, or the clear epoxy glue. Not doing so, might result in someone using the wrong product on his job, that will result in failure and confusion. Jim Patrick
JB Weld
Topic author - Posts: 2437
- Last Name: Patrick
- Last Name: Morsher
Re: JB Weld
One of my all time pet peeves is using any epoxy product on a historical auto made of nothing but metal, glass, rubber and cloth. When you are the caretaker you can do anything you want. It’s the poor guy down the road that will sadly discover epoxy in cracks, on radiators, rotten wood, anywhere a quick temporary fix is needed. Do it once and do it right. In my opinion, unless it’s something cosmetic, epoxy is just a bandaid temporary “fix”. Not really a fix at all.
This is burned into my brain, perhaps because real early in my working career I was tasked with digging pounds of epoxy out of the wood structure of a Packard body. Some well meaning “restorer” poured it in to take the place of missing and rotten wood.
You can all do what you like, and I’m sure lots will, but I’ve been on the receiving end WAY too many times of items repaired with epoxy and not told beforehand. Most should have been thrown in the scrap pile, some were worth and able to be repaired correctly. JMHO. We are only caretakers of our old cars, and should respect them better.
- First Name: Terry & Sharon
- Last Name: Miller
Re: JB Weld
Jim,
There are MANY versions of JB Weld. Marine, Plastic, Wood, Kwik, and the list goes on. Some of them are "old school". Some of them are the 5 minute types. Some even work in water. I know JB Weld has been around for at least 50 years. A product will not have that kind of lifetime if it didn't work.
- First Name: Jack
- Last Name: Putnam
Re: JB Weld
IF you are going to use an epoxy compound I think it is your responsibility to READ the label to see if you are going to use the product in the right application. One should not depend on someone else to tell you which product to use.
