Compression test
Topic author - Posts: 90
- Last Name: Seelman
- * REQUIRED* Type and Year of Model Ts owned: 15 touring
Compression test
Guys,
Interested in doing a simple compression test. A couple of questions 1. Warm or cold engine? and 2. All plugs out as each cylinder is being tested?
- Last Name: Nunn
Re: Compression test
Don't forget to fully open the throttle during the tests. You can't compress air that can't get in.
1: I prefer warm - 2: yes & 3: what Mark said !
It is ok to have the throttle closed or open, I really have never seen a difference between the two. I do my test cold, I am more interested in starting compression then running. Again, you can do them both to see how much difference between the two readings.
Compression test completed Saturday on a very cold engine (30 degrees) got 45#, 40#, 40#, and 40#. Plugs looked good #1 was sooty though
Thoughts??
Thoughts??
- Last Name: Rogers
- Board Member Since: 2013
Run the wheels off of it or do a complete rebuild.
- First Name: Mario
- Last Name: Brossard
How to do a compression test on engine without starter ?
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
I opt for running the wheels off........
Quickm007 - Crank and crank and crank
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),22Touring,22 TT,21 Fire Truck,14 Chief Car
Mario, it is still the same process.
The only thing different is that you get to turn the engine over with the crank
- First Name: Kevin
- Last Name: Matthiesen
Your cold compression test numbers, 45,40,40,40, would sujest why #1 plug was sooty. You are getting a little oil past the rings in #1 and #1 plug has a intermitid misfire. Try doing a wet compression. test with a little oil in the cylendars and all numbers will come up, with #1 coming up the least. Your cold dry numbers of 40 lbs are not that bad. I would keep driving the car, keep up with your maintenance and check the #1 coil & timer connections, replace #1 plug if needed.
Thanks Guys.....
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
I much prefer comp testing a low comp engine like the T when it’s cold. It gives a truer situation concerning starting the T when cold. Testing hot will give a false reading regarding cold starting. A modern with a comp of say 150 lbs. or better is relatively in affected by a 5 or 10 lb. drop. On a T that could be the difference between easy starting or not on a cold day. Do a dry then a wet test with the choke & throttle wide open. Write the results down. Don’t trust to memory. A VERY informative test concerning your engines condition. Especially if you’re pulling the head for no reason.
- Last Name: Juhl
Sooo.... what is the "good" compression range?
- Last Name: Rogers
55 PSI would be nice...
- First Name: Mario
Thank you guys, I will crank, crank and crank but my shoulder is painfull right now. Hope I will recover soon...
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
It's really easy with all but one plug out and the throttle positioned all the way open as well
- First Name: Keith
- Last Name: Gumbinger
Super Mario, Befriend a football player with wide shoulders and strong arms....
Keith
Keith
