WTB fire vehicle
Dellpound
First Name: Dell
Last Name: Pound
* REQUIRED* Type and Year of Model Ts owned: Looking
MTFCA Number: 17469
WTB fire vehicle
Post by Dellpound » Mon Nov 09, 2020 7:02 pm
Looking for a fire truck or chiefs vehicle. I’m in Southern California
First Name: craig
Last Name: leach
MTFCA Number: 26647
Re: WTB fire vehicle
Post by Craig Leach » Fri Nov 13, 2020 10:21 am
Hi dell,
What do you have in mind? I have a hose ladder truck but it is not a restoration its a frame up build on a stretched car frame with a muncie & rockies.
Mikes 1912
First Name: Lester
Last Name: Husted
* REQUIRED* Type and Year of Model Ts owned: 20
Post by Mikes 1912 » Fri Nov 13, 2020 11:39 am
Have a real 1922 model t LA City brush rig 90% finish resto. Mike 208 520 4892 mikes48ford@q.com
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Mon Nov 16, 2020 10:49 pm
please look at file below.
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
MTFCA Number: 21848
MTFCI Number: 22173
Post by rickd » Tue Nov 17, 2020 12:38 pm
There is a 14 Fire truck on Hemmings online.
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Sun Nov 22, 2020 9:32 pm
The Gandkids are all grown up know so the fire truck is not as much fun. The wife would rather have a closed car. T or A sedan?
Mike Denbar
First Name: Dr Mike
Last Name: Denbar
* REQUIRED* Type and Year of Model Ts owned: 1914 fire chief’s chemical car, 1925 touring fire chief’s car
MTFCA Number: 52242
Post by Mike Denbar » Mon Nov 23, 2020 9:25 am
Dell , If interested please contact me at mikedenbar@gmail.com. 1914 model t chemical car, chief, total new. Thanks. Mike Denbar
Loftbed
First Name: Rod
Last Name: Letcher
* REQUIRED* Type and Year of Model Ts owned: 1915 Speedster
MTFCA Number: 32097
Post by Loftbed » Wed Dec 23, 2020 7:33 pm
if you've got 30K I might be persuaded to part with this beauty, It's got everything including:
 1913 Ford Model “T” Speedster
 Correct '13 crank and handle, rebuilt w/ new shaft
 "More Drop" dropped front axle with 26-7 re built spindles and modern tube shocks
 Reversed eye main leaf on tapered leaf front axle. Teflon inserts in leaves
 Motorcycle front disc brakes with magnetic discs for digital speedometer
 Braided stainless brake lines from frame to brakes front & rear
 Custom double wishbone with new 1.25" ball and axle/shock brackets
 Mae West type shackles drilled for grease Lubrication
 Tie rod and drag link have modern ball type rod ends.
 Steering box, rebuilt Vega
 Early style front engine/spring mount w/ new U bolts
 Brassworks radiator with fittings for temp. gauge & electric fan probes
 under hood fill & overflow tank
 Electric fan, activates at 180 degrees with preset temp or hot switch mounted under dash
 Z High compression head (6 to 1 compression ratio and extra water capacity, adds approximately 7 HP).
 Foot feed accelerator.
 Turn signals with actuator switch in seat riser
 Ruckstell 2 speed rear end
 Leather upholstery.
 Four-wheel disc brakes,
 Seat gas tank and trunk movable fore and aft (all as one unit).
 Vega steering
 Light in the "trunk"
 Throttle cables accommodate foot and hand throttles.
 12 volt Alternater
 Fuel pressure Gage
 Water temp gauge
 Speedometer
 Tachometer.
 Voltmeter
 Note air filter
 Brass radiator
 Brass E&J headlights converted to Halogen.
 Brass E&J kerosene side and rear lights converted to LED.
 Brass Piriell horn and hose
 Custom oak wood dash and turtle deck
 New canvas top and straps
 Dual exhaust manifold connected to dual straight pipes
 Seat belts.
 Alternator.
 Modern carburetor
 Dual tail lights
 New White wall tires
 24” Brass fire extinguisher
 Brass fire bell
 Brass step plate
 Spare tire cover
ENGINE # 14-420-695 October 1926
 Aluminum Z head
 Bored .030 over and decked .010
 All new babbit by Mike Riechter
 Aluminum pistons
 Rods straightened re-babbited and
 balanced, with oil dips
 Late crankshaft reground & balanced to lightened flywheel with new ring gear and heavy duty oil slingers
 Stipe .280 cam with all new cam bearings
 Dan McEachern timing gears, bronze cam gear
 Stainless valves with hardened seats,
 new valve springs
 new adjustable tappets .015" over
 Texas T water pump
 Electric fan, activates at 180 degrees with preset temp or hot switch mounted under dash
 Billet aluminum crank and water pump pulleys with micro grove belt
 Texas T alternator, 12volt
 Texas T distributor with Pertronics electronic ignition conversion.
 Aluminum High volume intake manifold
 Modern Texas “T” carburetor and K&N air filter
 Chaffins Cast iron Dual exhaust
 Manifold with dual pipes to rear of car
 Completely rebuilt and balanced transmission with:
 Turbo 400 clutch using custom hub to fit to stock turbo discs From Lang's
 Heavy duty clutch spring and new brake drum lug shoes
 new large discs
 3 to 1 rear end gearing
 "Completely new" Ruckstell Axle Kit including early style shifter body and new shift handle and linkage.
:D
1965 Shelby Cobra (Factory Five repo)
1957 Ford Thunderbird
1941 Ford PU
Dellpound
First Name: Dell
Last Name: Pound
MTFCA Number: 17469
Post by Dellpound » Thu Dec 24, 2020 11:42 am
Incredible vehicle but to rich for me. Thank you for letting me know about it.
