26 Roadster Speedometer Cable Support
Topic author - Posts: 150
- First Name: Jim
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
How is the speedometer cable on a 26 Roadster supported? Laying on the tie rod doesn't seem appropriate. Photos of your installation would be appreciated.
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
Re: 26 Roadster Speedometer Cable Support
I made a bracket that was bolted to the frame and held the cable about mid way to the area that it went into the car.
- Last Name: Morsher
I had one but sorry, no picture. I believe it was a woven web strap, not leather like the earlier stuff. Speedos were options then.
- First Name: Jim
- Last Name: Wilson
A bracket or some sort of support midway seems reasonable. That's what I had in mind. A strap of some sort may have been the original way.
For the stewart cable I use a cable clamp & spring mounted to the frame.
My 25 roadster with Corbin speedo required a device to hold it up and also away from the front radius rod. I threaded a cable/zip tie through a short length of 1/2" flared copper pipe, around the cable, back through the pipe and around the radius rod to fix it in place. This supports the cable at the same time keeping it held away from the radius rod. A plain strap would still allow it to swing either side.
