Seing the electric specs for our trembler coils set me off to speculate:
We have an oscilator circuit here with a coil and a condenser so I wonder what the resonanse frequency would be for that circuit?
The formula for that is: According to the specs for a 1926 coil we have the primary (low voltage) coil of 0,0033 Henry (Henry is the unit for electromagnetic coils socalled inductance). The condenser we use to put in is 0,47 pF or 0,00000000000047 F. 2xPI is set to 6,283 for ease.
That give me a resonanse frequency of 4 MHz (4,041,355 Hz). This is for the isolated primary circuit. I am aware of the the secondary circuit may influence the inductance of the primary coil, but I do not know how much. I do not think it will change the resonance frequenzy several orders of magnitude, so we are talking MHz.
Given that the magneto gives out 16 Hz per revolution that will be 32.000 Hz or 32 kHz at 2000 RPM which is in the very high end of the Model T engines RPM interval.
So - as over 100 years of experience have showed - not an immidiate problem.
Have I missed something (I know there are electronic engineers around here - I'm just a mechanical engineer so what do I know
