Wire wheels and hubs question
Oldrusty26
First Name: Travis
Last Name: Melnick
* REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT etc...
Board Member Since: 2012
Post by Oldrusty26 » Mon Nov 01, 2021 12:23 pm
Picked up rear end that was made into a trailer , has decent wheels and hubs , my question is , how come the drums sit so close to the plates ? Would the brake parts keep them out where they should be if they were present ? I haven’t opened up the home made cover that closes the driveshaft area up and I assume the rear end to be parts , no experience with wire wheels as the cars I have are are wood spoked . Definitely T wheels etc , couldn’t pass on it for $40.00
Re: Wire wheels and hubs question
Post by Mark Gregush » Mon Nov 01, 2021 12:29 pm
Because you have wire wheel/hubs mounted on a small drum rear end, the backing plates are in different places on the 1926/27 rear ends. They were moved back towards the center. Even if the guts are shot, great deal at $40!
Post by Steve Jelf » Mon Nov 01, 2021 12:36 pm
If they are actual Model T wheels and in good shape, you got a smoking hot deal. Model T wheels for the price of Model A wheels.
The only reason I can think of for that position of the drums would be shortened axle shafts.
Post by speedytinc » Mon Nov 01, 2021 12:40 pm
Dittos.
Is that a 15 or earlier rear end? Smooth backing plates? Double score!?
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Mon Nov 01, 2021 1:51 pm
Thx , definitely T wheels , not sure about rear end , will get more pics when I get home, thanks again !!
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Mon Nov 01, 2021 5:54 pm
Here are pics of differential
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Mon Nov 01, 2021 5:57 pm
Hopefully better pics
Kerry
Last Name: van Ekeren
Post by Kerry » Mon Nov 01, 2021 5:59 pm
Yep, 1915/16 diff. Don't know about the spring thou, will need to see some photo's of the top of the leaves to tell.
Oldrusty26
First Name: Travis
Last Name: Melnick
Post by Oldrusty26 » Mon Nov 01, 2021 8:50 pm
Thanks for the info about the differential , the drums and rims are what I was after ,now to luck into a set for the front , lol !! the springs don’t look familiar to me , and not sure what the crossmember is from , think it’s bigger than a tt , possibly an A ? At any rate , I will most likely never own a ‘15 , but the rear differential will go into the barn to sit with the rest of the parts until someone can use it !!
