Valve Cover 1927
Greg sarky k
Topic author - Posts: 35
- First Name: Gregory
- Last Name: Kojoyian
- * REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo,1912 Touring,1912 Torpedo ,1913 Touring
Valve Cover 1927
What is the correct color for valve covers in 1927?
Greg
Greg
- Last Name: House
Re: Valve Cover 1927
...engine color
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
In general, for 26-27, cast parts are moleskin, stamped parts are black.
J1MGolden
- Last Name: Golden
I have always wondered about that or what color moleskin is, as I have never seen a green mole.
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
ModelTWoods
- First Name: Terry
- Last Name: Woods
Does the MTFCA Encyclopedia give this information? Painting the stamped steel parts a different color than the cast parts' color, would certainly set them off, but I can't believe Henry Ford would put that expense into a Model T engine. It took him 18 years, just to change the head bolts and some other engine hardware from painted to nickle plated.
Joe Bell
- First Name: Joe
- Last Name: Bell
There was so many sheet metal parts made and it came down the line for 24-5 they got throwed on a 26-7 to use them up so it was not taking more time he was using up old parts. I have seen on original cars a 13 front fender on a 14 and the other side being a 14 fender, it does not take much to notice a body line in a fender but it happens!
ModelTWoods wrote: ↑Sat Nov 06, 2021 10:36 pmDoes the MTFCA Encyclopedia give this information? Painting the stamped steel parts a different color than the cast parts' color, would certainly set them off, but I can't believe Henry Ford would put that expense into a Model T engine. It took him 18 years, just to change the head bolts and some other engine hardware from painted to nickle plated.
Here is info from MTFCA Encyclopedia, that valve cover was painted engine color, black if black engine, and green if green engine (Moleskin). This is for late Improved cars with the Vaporizer carb set up.
- First Name: Jeff
- Last Name: Humble
Found this picture of the 15 millionth model T. This one looks like Model A engine green and frankly this engine color is questionable since the body has been repainted the wrong color two different times, the engine could have been repainted at some time too.
