Header Build and Firewall Dishing all in a Day!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Nov 20, 2021 6:54 pm
First Name: Henry
Last Name: Lee
Re: Header Build and Firewall Dishing all in a Day!
Post by Henry K. Lee » Sat Nov 20, 2021 6:59 pm
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sat Nov 20, 2021 7:31 pm
Nice Hank! You make it look easy my friend.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat Nov 20, 2021 8:52 pm
Beautiful work!
Last Name: Gregush
Post by Mark Gregush » Sat Nov 20, 2021 10:09 pm
Very nice! If I install the Chevrolet over head on my 1925, will need to do the same. I really like your approach. Thanks
Post by Rich Eagle » Sun Nov 21, 2021 12:25 pm
Both are nice, clean work.
What fun.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sun Nov 21, 2021 12:58 pm
More to add. Heavy support at the Y pipe to prevent metal fatigue.
Spark plug wire cross over duct when using an outside Magneto or distributor.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Mon Nov 22, 2021 10:11 am
Very nice job. As a retired Boilermaker welder I understand the amount of grinding and polishing it takes to smooth out the weld zones. When I worked at the Nuclear power houses we had to make all our welds look like that. It's hard to see in the picture, but it appears you added a 1/4 turn "twist" to the lower header support. Little details like that make the brackets stronger and add one more little design feature to the project.. Again,very nice job .........
