Period Split Wishbone Setup
Tim Rogers
Topic author - Posts: 387
- Last Name: Rogers
Looking for photos or information on Model T split wishbone setups from the 1920s or 1930s. I am particularly interested in how the wishbone rod mounted to the frame. I don't really want to use a modern ball joint style mount as it won't look correct.
Re: Period Split Wishbone Setup
Here are a few
Two more (I have both - haven't decided which I am to use)
Hank's
Hank's
- Attachments
- HANK s.jpg (83.5 KiB) Viewed 3068 times
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Using Model A Tie Rod ends is another method. Not 100% era correct, but much better than using heim joints or modern tie rod ends.
Model A designs
henryford2
- First Name: Joseph
- Last Name: Andulics
These are Ford 8N parts. Might be helpful if your'e scratch building your radius rods and they do have the "vintage look". Readily available on Ebay. Enjoy
Since your cars already have the tried and true under-axle wishbone I'm only curious as to why you want such a
set up? Man that is one wicked looking contraption for sure! I reckon it would be great, if not necessary, should your
roads be filled with lots of potholes and rough as a washboard.
Tim Rogers
- Last Name: Rogers
Tim- my lowered front end set up requires splitting the wishbone.
Ah haaa....makes sense. Thanks.
The other Tim
The other Tim
