Looking for some history on MTFCA Rad Badge
My1914T
First Name: Ross
Last Name: Benedict
* REQUIRED* Type and Year of Model Ts owned: 1920 Drs. Coupe
Post by My1914T » Tue Apr 16, 2019 6:24 pm
I've lightened for clarity slightly
Have been working on an estate sale clean up, of a long time member, and found this Rad Badge amongst the 'treasures'.
We are wondering if it's an early MTFCA badge? or a well made replica of the MTFCA logo. It appears to be aluminum, with a 'Scotch® No. 467' adhesive backing. Measures a hair under 3 1/2" The lettering appears to be hand applied, not a newer true graphics print.
Thoughts??
Re: Looking for some history on MTFCA Rad Badge
Post by Mark Gregush » Wed Apr 17, 2019 1:58 am
Can't help much except the emblem and title on the Vintage Ford mag looks to have been standardized with the Volume 35, Number 3 May/June 2000 issue. Before that the title and emblem were in several different colors even in a years worth of issues. While it could have been used after that date it looks like would have been used prior or maybe a little past. Looking in the mag is no help as a quick check, I don't see any color photos before Volume 38, Number 5 Sep/Oct 2003. Might check with someone at the headquarters.
My1914T
First Name: Ross
Last Name: Benedict
Post by My1914T » Wed Apr 17, 2019 5:12 pm
Thanks Mark. I'm hoping the MTFCA office or those close will add to this.
Post by Mark Gregush » Wed Apr 17, 2019 5:47 pm
You might try sending a note to AdminAleesa. At the bottom of the page in the contact bar, open "the Team"
23ford
First Name: Warren
Last Name: Webb
Post by 23ford » Wed Apr 17, 2019 5:56 pm
I got some these from Ben Yumori at the national convention I put together years ago. I seem to remember him telling me he had these made to promote the club.
My1914T
First Name: Ross
Last Name: Benedict
Post by My1914T » Wed Apr 17, 2019 8:23 pm
Thanks Warren, do you have a rough idea on a year??
Ross
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Fri Apr 19, 2019 11:34 pm
From memory, following discussions with Bruce McCalley, he mentioned his son drew the logo when the MTFCA was first envisioned. Indeed that logo is on the upper right side of the cover of issue 1 of The Vintage Ford. The style you mention was available in 1976 when I bought one for my Coupe. I put mine on the original radiator. A plastic one was made available from the club store and is now on the drivers rear window on the coupe.
So they have been around for a long time
Tony Bowker
La Mesa, California
My1914T
First Name: Ross
Last Name: Benedict
Post by My1914T » Sat Apr 20, 2019 1:22 am
Thanks Tony.
