Good afternoon forum Chums!
I just thought I would give you all an update. I just got off the phone with Steve at Lang’s antique auto parts and he said replacement cams are nowhere in sight….. In spite of whatever rumors you may have heard, there are no cams even in production at present and no definitive date is to when camshaft productions are going to be resumed…. I guess I’m going to have to nurse my original stock Cam along a little while longer!
If anyone has heard anything different than that please reply back here….. Have a great day people!
Camshaft timelines
Flyingpiper59
Topic author - Posts: 140
- First Name: Edwin
- Last Name: Douglas
- * REQUIRED* Type and Year of Model Ts owned: 27 Tudor
SleepyT
- First Name: Russell
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1921 touring, 1914 roadster, 1913 roadster
Re: Camshaft timelines
Chaffins garage has a 270 re ground camshaft that works great and is quite reasonably priced.
Russell
Russell
This cam does perform very well. Follow the instructions on front thrusting!
The stipe cam is much more beefy & not prone to the flexing of a thinner reground cam.
You could also use original grind and 7.5 degree advanced timing gear.
J1MGOLDEN
- Last Name: Golden
What does that 7.5 degree advance due for performance?
Moxie26
- Last Name: Jablonski
That cam gear makes the engine a little bit more peppier.
