Icons
FundyTides
Topic author - Posts: 225
- First Name: David
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Icons
Icons don't change color to indicate topics that I have already read. All postings remain red. I am signed in What am I doing wrong?
AdminJeff
- First Name: Jeff
- Last Name: Stevenson
Re: Icons
They do if you click refresh or click on the link at the top of the page to get back to the topic list. You are probably hitting the back arrow on your browser. That takes you back one screen but does NOT refresh the page. 2 fixes
Hit refresh after going back or use the next topic button and then go back to the index. This is a browser issue on your end.
Here’s what they look look like when working. The middle one has been read.
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
FundyTides
- First Name: David
- Last Name: Wilson
Re: Icons
Jeff, Thanks for the quick reply. You are right, if I click on "reload this page" the icons that I have read change color. A bit cumbersum but I assume if I just do this before I leave the forum each time the icons will get updated or do I have to do it each time I leave a particular topic?
AdminJeff
- First Name: Jeff
Re: Icons
When the list is updated is up to you. The next time you visit the forum the list would be updated. It’s the Same for new topics. If you stare at the page of topics for a day, you’d never see new topics. You have to refresh your browser to see new anything.
Jeff
Jeff
fschrope
- First Name: Fred
- Last Name: Schrope
- * REQUIRED* Type and Year of Model Ts owned: 1923, 1926, 1927 TT's, 1918 cutoff touring, 1922 Coupe - original
Re: Icons
I've never understood why folks don't refresh the main page and then "right click" the topics that interest them and "open in a new tab". Do the whole page and then read the tabs and close them as you're done reading them. Simple...........at least to me and it applies to all the different browsers I've used. It will even work pretty well with "dialup".
ChrisB
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
Re: Icons
Also if you use the link at the bottom of the page
Return to “Forum Support Questions”
the icons should display properly.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
