Which Steering Wheel?
Gen3AntiqueAuto
Topic author - Posts: 415
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
I took the original one out years ago to make it easier to use the drivers door. Thinking I would be happier with a little more control so I'm considering a change. Which one should I put in the car, or keep the same?
https://youtube.com/shorts/Kep3hCOQKYc
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
Re: Which Steering Wheel?
Honestly, none are "original" to the year of your T. I would definitely NOT use the little one.
I use a large, aftermarket wheel on my 14 for the extra control.
Gen3AntiqueAuto
- Last Name: Foye
So the original steering wheel that came off the car is not original?!?
Jerry VanOoteghem wrote: ↑Wed Nov 16, 2022 3:33 pmHonestly, none are "original" to the year of your T. I would definitely NOT use the little one.
What year car did you remove the black wheel from ?
Your car appears to be a 26/27. I believe it should have the stamped steering wheel with the arms riveted to the hub, and not the cast steering wheel spider.TheSpeedsterProject wrote: ↑Sun Nov 20, 2022 11:49 amSo the original steering wheel that came off the car is not original?!?
Gen3AntiqueAuto
- Last Name: Foye
I'll take better photos when I do the swap so we can all see what we're looking at.
Kerry
- Last Name: van Ekeren
My Canadian 26 and 27x2 touring's have cast spiders
Gen3AntiqueAuto
- Last Name: Foye
Apparently this is cast as well - this was an original car from Canada when I bought it.
https://youtu.be/kiUOcWsBpJQ
Is it a 17" wheel ?
Gen3AntiqueAuto
- Last Name: Foye
