26 Touring for sale
Topic author - Posts: 344
- First Name: Dennis
- Last Name: Prince
- MTFCA Number: 22802
26 Touring for sale
Has new rings, modern valves and adjustable lifters, 7 1/2 degree cam gear and head milled 125 thousands, balanced transmission and flywheel, cleaned and check radiator, rebuilt Ruckstell with left hand shifter, rebushed front spindles and pack bearings. All new wiring and added a brake light, new safety glass and battery a year ago. The body is solid and rust free, paint is not original, really dark green with black fenders, not a show car. Comes with top bows (metal parts), wood kit and upholstery kit, wheels are solid and tight, tires that are on it have a lot of tread but old, comes with a set of good used tires ( I don't want to change them). It runs and drives great.
Has a clear Oregon title. Asking $8,000-
- Last Name: Prince
Re: 26 Touring for sale
I can't find a way to update or delete a posting so I wanted to let you know that I am taking this car off the market for now. I am going to put the Ruckstell in another car and put the stock rear end back in and relist it at a later date. Thanks, Dennis
- Last Name: Prince
It's later and I have the standard rear diff in the car, the description is the same except it no longer has a ruckstell and the standard rear diff has safety hubs a cartridge pinoin bearing and a new u-joint. the asking price is now $7,146.26.
- Last Name: Prince
