F/S Overhead Valve Cylinder Head Lifter Cup Set
Topic author - Posts: 118
- Last Name: Chaffin
- MTFCA Number: 31705
These are used to convert your adjustable lifters over for use with pushrods when installing an overhead valve cylinder head. The cups replace the adjustment bolt on the adjustable lifters sold by the vendors. They accept a 5/16" pushrod ball. No need to bore out the lifter guides to accept the larger 292 Ford lifters as is past practice. The complete set of eight pieces is $125 plus $8.50 domestic shipping. PM me or call Mark Chaffin (951) 805-0928
Re: F/S Overhead Valve Cylinder Head Lifter Cup Set
If you are installing an overhead valve cylinder head, these make for an easy installation. Mark Chaffin (951) 805-0928
One set sold to Alex. Thanks Alex! Thanks MTFCA!
