Amp meter
Topic author - Posts: 100
- First Name: Bill
- Last Name: Barteldes
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coup
Amp meter
Langs doesn't have an amp meter. Mine is sticking. Is there a way to clean it? or somewhere else to get one?
BIll B
No matter how you shake and dance the last few drops go down your pants.
- Last Name: House
Re: Amp meter
What year switch/ammeter panel ?
- First Name: Bill
Re: Amp meter
24 Coupe and the key and switch are worn so i assume its original. And i love your quote by the way i have two dogs I rescued as well.
BIll B
- Last Name: House
Re: Amp meter
So you’re needing the larger diameter ammeter that is, unfortunately, not being reproduced
Go up to the top of this site to Board Index and find Classified Parts. List your need for an ammeter for a ‘24 coupe. You’ll get responses there
Re: Amp meter
The internal movement is a rather delicate mechanism. The question is why is it sticking.
I have some of the large ammeters. email sent
Re: Amp meter
Seems like the supplier who makes the Magneto meter could make an Amp meter. HMMMM
Re: Amp meter
The supplier that made the Magneto Meter was the same that made the large ammeters - Fun Projects. Now owned by BirdhavenJohn kuehn wrote: ↑Fri Mar 24, 2023 1:52 pmSeems like the supplier who makes the Magneto meter could make an Amp meter. HMMMM
- First Name: George John
- Last Name: Drobnock
Re: Amp meter
A 20-0-20 ampere meter can be found on early tractors. Ever think about looking at those who enjoy old tractors?
- Last Name: Golden
Re: Amp meter
If you need an ammeter, you probably need the switch and other parts as well!
The most likely part to be bad is the cylinder the key turns.
That part is usually broken on the top or bottom of the key slot.
They are not being manufactured now.
- First Name: Mike
- Last Name: Howell
- * REQUIRED* Type and Year of Model Ts owned: 23 Speedster, 26 Roadster
Re: Amp meter
Bill, my T has an ammeter that I believe is like yours. When it gets sticky, I remove the back of it and spray it real good with starting fluid. Let it dry, reassemble, and it's good for another 5 or 6 years. Electronic parts cleaner would probably work also, but I never seem to have any around.
"I refuse to join any organization that would have someone like me as a member." Mark Twain
- First Name: Bill
Re: Amp meter
oh great . thanks!Mike Howell wrote: ↑Fri Mar 24, 2023 9:29 pmBill, my T has an ammeter that I believe is like yours. When it gets sticky, I remove the back of it and spray it real good with starting fluid. Let it dry, reassemble, and it's good for another 5 or 6 years. Electronic parts cleaner would probably work also, but I never seem to have any around.
BIll B
- First Name: craig
- Last Name: leach
Re: Amp meter
The old tractor guys may be Steiner. SteinerTractor.com 1-800-234-3280 the one pictured is for a 2" hole Order # ABC016 for Ford tractors
1939-57 but sold for most with a 2" meter. For a few dallars more you can get one with favorit tractor logo.
Craig.
Craig.
- Last Name: Hjortnaes
Re: Amp meter
Did you try Snyders, Chaffins, Bob's, and Gaslight Auto?
