Show Us Your Holder For Registration and Insurance
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat May 20, 2023 12:16 pm
OK, I will admit I put my registration and insurance documents in a paper envelope, wrap it around the steering column, and secure it with a piece of string. I have seen the document holders the vendors sell, what do others use?
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Show Us Your Holder For Registration and Insurance
Post by ThreePedalTapDancer » Sat May 20, 2023 12:26 pm
I’ve been thinking about using a motorcycle registration holder like this. You could attach it anywhere.
Post by Rich Eagle » Sat May 20, 2023 1:24 pm
I made this out of top material using an original as a pattern. Not the best material but it does the job.
John Codman
Last Name: Codman
Post by John Codman » Sat May 20, 2023 1:42 pm
I have them plastic-laminated and put them under the rear floor mat.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Sat May 20, 2023 3:00 pm
I keep my paperwork for my Touring in a vintage metal Ex-Lax tin and use a couple of small magnets to stick it on the front seat riser on the driver’s side just below the seat spring.
Figured no one would want anything to do with it!
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by TFan » Sat May 20, 2023 6:01 pm
Got this several years ago in a goody bag at a car show. Water-proof and hard to miss when and if needed. Very good for the open car, boaters use them for the same reason. Jim
Post by Mark Gregush » Sat May 20, 2023 7:36 pm
Out of site, plastic baggy between the cushion and tank cover.
Post by DanTreace » Sat May 20, 2023 8:26 pm
Steering column mount, vinyl plastic. Moisture proof. Easily read by law enforcement.
But. Haven't been pulled over ever in my Ts :)
Michael Peternell
First Name: Michael
Last Name: Peternell
Post by Michael Peternell » Sun May 21, 2023 12:50 am
Just saw this thread. That's by far the least of your worries! If you come across a police man that would actually spend the time checking it out.
I'd like to his boss about more serious things he should be spending time worrying about!
Flivver
First Name: Steven
Last Name: Park
* REQUIRED* Type and Year of Model Ts owned: 1926 runabout
Post by Flivver » Sun May 21, 2023 9:21 am
Brilliant!
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Sun May 21, 2023 9:28 am
I get pulled over all the time but they just want to know about the car and have only asked for license and registration once! I keep them in a plastic sandwich bag in the battery box on the running board.
Loftfield
First Name: Thomas
Last Name: Loftfield
* REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1912 Express Pick-up
Post by Loftfield » Sun May 21, 2023 11:12 am
Under the back seat. Who cares? At 30mph no one is ever going to stop you for anything other than getting a good look. At least here in North Carolina no one gives a flip about cars as old as Model T.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sun May 21, 2023 12:02 pm
In Minnesota, only vehicles that are taxed based on gross weight are required to have a "cab card" (proof of registration and gross weight). Therefore, for a passenger vehicle, a peace officer will only ask for proof of insurance but not for proof of registration (and, frankly, the license plate displayed on the car is proof of registration).
Unless your state requires it, I don't see the point of publicly displaying the registration and/or insurance card, for example, on the steering column or visor. Just as long as the required documents are stored somewhere in the car should suffice. I also carry copies of the insurance cards in my wallet.
StevenS
First Name: Steven
Last Name: Sebaugh
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
Post by StevenS » Sun May 21, 2023 12:08 pm
I have all my information in a plastic zip lock bag. Then I place it under the middle of the floor mat, front or back seat area. Stays nice and flat that way. In the TT truck it, is under the seat in the side areas.
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
Post by Original Smith » Sun May 21, 2023 3:44 pm
Put them wherever you wish! I keep mine under the seat where they can't be seen!
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Sun May 21, 2023 3:46 pm
Mine are in my wallet.
DaveBarker
Last Name: Barker
Post by DaveBarker » Mon May 22, 2023 8:23 pm
When I rebuilt the Speedster body I built-in a small slot in the gas tank space behind the passenger seat. I put the registration, insurance card, and inspection sticker (NYS) in a zip-lock bag in the slot. Right next to my gas gauge ( :D ). Haven't been pulled over yet, but if I am, I'm ready!
