My rebodied 27 speedster
Topic author - Posts: 353
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
I'm posting a few pictures of my 1927 speedster that I made A change in the body from a buckboard style to a 27 roadster cowl with a complete windshield. This car had an engine failure back in 2001 and I decided to change the body at that time This coming labor day is the anniversary of the engine failure. Things got in the way of getting it back running till this year (2023). I think it turned out pretty nice. I also used a whippet radiator.
- Last Name: Pharis
Re: My rebodied 27 speedster
Lookin good Tom! Those Ash wire wheels are lookin sharp as well. Hope to see you this weekend in Eagle Creek, OR for the speedster run…
- First Name: Andrew
- Last Name: Clary
Good work Tom, wish we were headed up this weekend.
Andy
Andy
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
where in Eagle creek is the starting line? How many cars are signed up?
Tim
Tim
- First Name: Walt
- Last Name: Berdan
16 registered to participate. Host site / starting point is Eagle Creek Lavender Farm on Starr Rd.
Social and mini tour on Saturday, 200 miler on Sunday.
- Last Name: Wightman
Tom, Are you using the original plumbing (inlet pipe and exit pipe) on that Whippet radiator? If so, does that work OK on your T motor, especially with the overhead? How'd you do that? I want to put my Whippet radiator on my speedster but I was worried I'd have to change out the plumbing to match the size of the water pipes on the head and block.... Rollie
- First Name: Chad
- Last Name: Azevedo
Good question, I've been pondering the same decisionSouthfork Creek wrote: ↑Thu Aug 31, 2023 5:46 pmTom, Are you using the original plumbing (inlet pipe and exit pipe) on that Whippet radiator? If so, does that work OK on your T motor, especially with the overhead? How'd you do that? I want to put my Whippet radiator on my speedster but I was worried I'd have to change out the plumbing to match the size of the water pipes on the head and block.... Rollie
I had new Model T size brass inlet & outlets pipes made by my local, now retired radiator repair guy 30+ years ago that modified & attached to my Whippet radiator - original Whippet coolant pipes are quite small !
