Mag Horn for sale Sold
Topic author - Posts: 354
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- Board Member Since: 2013
Magneto horn with mounting bracket. The horn is in need of a clean up. I think it works as It make a sound when I touched it to a 12 volt. Price is $75.00 plus the ride. Tom five03-644-937four. It appears to be in good shape with no dents.
- Last Name: Tannehill
Re: Mag Horn for sale
Tom might not be good for the horn to test it with a battery.
Best John
Best John
Just touching it to 12 volts DC should not hurt it. It is just an electromagnet using AC that pulls the diaphram back then releases it 16 time per revolution of the flywheel. Checking it on DC would tell you that the windings are working when you hear the "clunk".
- First Name: Jim
- Last Name: Davis
If You have a old toy train transformer that should work to test it. adjustable voltage 0 to 24 volts a/c. 60 cycles
- First Name: Tom
Horn Has been Solded. Tom
