23-5 top bow work on 26-7 body???
Nv Bob
Topic author - Posts: 799
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Have set of top irons forsale that they where late style but seems they are earlier had lots inquiries
If they would even ot correct ???
Re: 23-5 top bow work on 26-7 body???
Your set seems really screwy.
Its too complicated for a roadster.
It most like a 27 touring, except its missing a bow? & the body attach point bow should be curved.
They look fine to me for a 23-25 Roadster.speedytinc wrote: ↑Mon Dec 04, 2023 3:44 pmYour set seems really screwy.
I have a 26 Roadster but it has earlier bows, most likely 25. They fit fine and the top works, however, it is more straight in back than it would be with the correct bows. See picture e
- Last Name: Tannehill
Bob like I posted in the classifieds. If you look you’ll see the thin supports that strengthens the total assembly as in a set of sockets for a touring. Maybe someone made those or it’s for another style car. The 23-25 roadster sockets are a simple affair. 3 sockets on each side, no metal webbing between the sockets. Straight & clean. Below are pictures of the sockets mounted on the tub of a 1923-5 roadster or cut off roadster can’t tell for sure. I believe these are from the build Mark Strange was doing. Hope you don’t mind me using them Mark. Best John
- Attachments
- IMG_3475.jpeg (74.3 KiB) Viewed 1474 times
Nv Bob
- First Name: Bob
Well not T but several said there A 28-9
So pulled the ad
So pulled the ad
