A what is it question
CTLeonard
Topic author - Posts: 1409
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
The local VFW regained possession of a T that was original to the little town. One thing that sticks out is the hole in the cowl . Sure looks to be a factory looking hole. Anyone know what it is? Thank you
Re: A what is it question
With a matching hole on the passenger side, would think someone added electric cowl lamp that had single post, like early Chevy.
Or could have used a later Model A style cowl lamp, those have a post with flange the might have made that impression in the sheet metal.
This fancy runabout had lots of extra lamps, one on the fender, one on the cowl and even the dressy 'lantern' on the running board!
For a spare tire carrier?
That whole cowl is not original. It should be flat from the hood to the door.
I think the question is about more than strictly the hole. I think the OP is wondering also about the formed area around the hole. Other than that, this appears to be a stock cowl.Norman Kling wrote: ↑Thu Mar 28, 2024 11:22 amThat whole cowl is not original. It should be flat from the hood to the door.
Look at the first picture. The cowl between the hood and the door. Not just around the hole. That raised area to the left of the door looks similar to a 1928 or 1929 A. The whole panel from the hood to the door should be flat. See picture attached.
You are correct Norm but it is a closed car cowl.
The car in question is a Sedan or Coupe. The car you pictured is a Roadster. Two totally different cowl shapes.Norman Kling wrote: ↑Thu Mar 28, 2024 12:32 pmLook at the first picture. The cowl between the hood and the door. Not just around the hole. That raised area to the left of the door looks similar to a 1928 or 1929 A. The whole panel from the hood to the door should be flat. See picture attached.Rumble3.jpg
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
If it just has the one hole, my guess would be that it was for a radio antennae.
I didn't realize the second picture posted was of a different car. I guess I was wrong.
signsup
- First Name: Robert
- Last Name: Brough
- * REQUIRED* Type and Year of Model Ts owned: 1915 War Wagon 1927 Depot Hack 1927 TT
In my other hobby, military vehicles, we wonder till the cows come home what Bubba drilled that hole for. We may never know. If it's drivers side, my initial thought would be some sort of spot light. I would think most radio antennas get mounted on the passenger side, but it's Bubba's car, he can do with it what he wants.
I guess the consensus is that it is not factory. So, what for? The world wonders.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
A bunch of old cars
Sometimes they run.
Bryant
- First Name: Bryant
- Last Name: Shafer
Maybe since it is original to the town there is someone left that knows what was there or has pictures of it from the past.
Bryant
Bryant
There were some bun type side lights with fixed mounting studs on the side rather than the usual rear studs. If there is a corresponding hole on the other side, they could be sidelight mounting holes. The indentation is such that it would aim the lights to the front. It would save the cost of the brackets, something of which Henry would approve.
If the T has the original coils, the radio would not work. I have driven a modern car with an AM radio while the T was idling. The radio had static for about 200' from the house. Maybe if they had a distributor they could modify it with resisters or resistor plugs or something like the modern cars use.
Would think the VFW would have photos from the past showing the car in action or the local newspaper.
