Creating this WWI ambulance and mounting the cowl lights on a flat wooden dash/firewall/cowl and looking for two brackets to do so. Had used two on another wooden dash project vehicle that bolted to the wood and then the cowl light bolted to the bracket. Looking for two, maybe three if I decide on a single tail light with no license plate frame.
Let me know if you have something and what you want. Should fit in small or medium USPS priority flat rate box for $15.
Thank you.
WTB: Cowl Light mounting brackets to wood cowl.
Topic author - Posts: 472
- Last Name: Brough
- * REQUIRED* Type and Year of Model Ts owned: 1915 War Wagon 1927 Depot Hack 1927 TT
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
A bunch of old cars
Sometimes they run.
Re: WTB: Cowl Light mounting brackets to wood cowl.
What type of lamps are you going to use ? Makes a difference in the style of bracket.
- Last Name: Brough
These are my proposed lamps. Its' what I have on the shelf right now. One has the castle nut and hole in the rod for the cotter pin and one just has a threaded rod bolt and nut. But came off same win
A bunch of old cars
Sometimes they run.
A bunch of old cars
Sometimes they run.
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
I think I have one flat cowl mount
- Last Name: House
You mean like these ???
- Last Name: Brough
George, yes, exactly like that. Unfortunately, I forgot that I had this thread out here and have changed the design of the firewall and cowl so that I no longer have a flat surface to work with. The cowl I have created is sloped towards the front and I now need to fabricate some sort of straight strip that will come flat out from my dash panel and allow me to mount a forward facing cowl light to it. So, no right angles in it at all. Just mounting holes and a single cowl bolt hole on the same plane.
A bunch of old cars
Sometimes they run.
A bunch of old cars
Sometimes they run.
